This guide will walk you through how to authenticate or reauthenticate Bing Webmaster Tools for Supermetrics in Google Sheets, Data Studio, and Microsoft Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Bing Webmaster Tools, webmasters need an API key. Follow Microsoft’s instructions to generate this API key.
For Excel users
- Click Create query.
- Under Data source, select Bing Webmaster Tools.
- Enter your API key and click Start.
- Under Select sites, select websites.
When you're ready, learn how to create your first Supermetrics query with Bing Webmaster Tools.
- Navigate to Bing Webmaster Tools and click Try.
- Click Authorize. If you're authenticating Bing Webmaster Tools for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Under Select sites, select websites, and click Next.
- Select the query type.
- Click the edit icon next to Bing Webmaster Tools in the Data Studio sidebar.
- Scroll down to Parameters.
Before you can authenticate Bing Webmaster Tools in Excel, you need to install the Supermetrics add-in.
- Under Select sites, select your websites.
- BigQuery
- The Supermetrics API
Reauthenticate
