This guide will walk you through how to authenticate or reauthenticate AdRoll with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Adroll, you need Administrator or General User role access. Learn how to add or edit an AdRoll user in AdRoll's documentation.
For Excel users
- Click Create query.
- Under Data source, select AdRoll.
- Enter your email address and password, and click Sign in.
- Select your accounts.
When you're ready, learn how to create your first Supermetrics query with AdRoll.
- Navigate to AdRoll and click Try.
- Click Authorize.
- Click Authorize.
- Scroll down to Parameters.
- BigQuery
- The Supermetrics API
