AdRoll connection guide
Follow these steps to connect your AdRoll data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to AdRoll, you need Administrator or General User role access. Learn how to add or edit an AdRoll user in AdRoll's documentation.
  3. Click Create new query.
  4. Under Data source, select AdRoll.
  6. Click Start.
  7. Enter your email and password, and click Sign in.
  8. Click Authorize.
  2. Navigate to AdRoll and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "AdRoll requires authorization to connect to data").
  7. Click Start.
  8. Enter your email and password, and click Sign in.
  9. Click Authorize.
  10. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. Click Create report.
  13. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select AdRoll.
  5. Click Start.
  6. Enter your email and password, and click Sign in.
  7. Click Authorize.
Data warehouse
  3. Click + Create transfer.
  4. Select the AdRoll data source.
  7. Accept the agreement.
  8. Click Authorize with AdRoll.
  9. Click Start.
  10. Enter your email and password, and click Sign in.
  11. Click Authorize.
  13. Click Submit.
  14. Click Save.
  2. In the sidebar, go to StorageTransfers.
  3. Click New transfer. If you haven't created any transfers yet, click Schedule first transfer
  4. Select the AdRoll data source, and click OK.
  7. Click Start.
  9. Click Authorize.
  11. Click Create transfer.
Power BI
  2. In the sidebar, go to DestinationsPower BI.
  3. Click Create or edit queries.
  4. Click Select a data source.
  5. Select the AdRoll data source.
  6. Click Start.
  8. Click Authorize.
  9. Fill in the query details.
  10. Click Run query to test your query.
The Supermetrics API
  2. In the sidebar, click API.
  4. Click Select data source.
  6. Click Start.
  8. Click Authorize.
Supermetrics Hub
  2. In the sidebar, click Data sources.
  4. Hover over the AdRoll data source, and click Connect.
  5. Click Start.
  7. Click Authorize.
