HubSpot connection guide
Follow these steps to connect your HubSpot data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, and data warehouses, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect, you'll need a HubSpot account with either of these user roles:
  • Admin
  • Super Admin or Owner (full access)
  3. Click Create new query.
  4. Under Data source, select HubSpot.
  6. Click Start.
  7. Enter your email and password, and click Log in.
  8. Click Allow, and then choose an account.
  9. Click Grant access.
If you see a message reading "Request for integration permissions", your account doesn't have the permissions it needs to connect to Supermetrics. Contact your HubSpot administrator for help.
  2. Navigate to Hubspot and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "HubSpot requires authorization to connect to data").
  7. Click Start.
  8. Enter your email and password, and click Log in.
  9. Click Allow, and then choose an account.
  10. Click Grant access.
  11. Scroll down to the bottom of the page. To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
  12. In the pane's top right, click Connect.
  13. Click Create report.
  14. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select HubSpot.
  5. Click Start.
  6. Enter your email and password, and click Log in.
  7. Click Allow, and then choose an account.
  8. Click Grant access.
Data warehouse
  3. Click + Create transfer.
  4. Select the HubSpot data source.
  7. Accept the agreement.
  8. Click Authorize with HubSpot.
  9. Enter your email and password, and click Log in.
  10. Click Allow, and then choose an account.
  11. Click Grant access.
  12. Define the transfer settings.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the HubSpot data source, and click OK.
  10. Click Create transfer.
The Supermetrics API
  4. Click Select data source.
  5. Select the HubSpot data source.
Supermetrics Hub
  4. Hover over the HubSpot data source, and click Connect.
  5. Enter your email and password, and click Log in.
  6. Click Allow, and then choose an account.
  7. Click Grant access.
