This guide will walk you through how to authenticate or reauthenticate HubSpot in Supermetrics with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to HubSpot, a Hubspot account with Admin rights. For full access, the user role Super Admin or Owner is required. Learn more about user roles in HubSpot’s documentation.
- Under Data source, select HubSpot.
- Enter your email address and password, and click Log in.
- Click Allow.
- Choose an account.
- Click Grant access.
- If you see a message that says "Request for Integration Permissions", your HubSpot subscription administrator will have to grant you higher permissions before you can proceed.
Select accounts to include in your reporting.
- Navigate to HubSpot and click Try.
- Click Authorize.
- Click Authorize.
- Click Allow.
- Choose a HubSpot account.
When you're ready, learn how to create your first Supermetrics query with HubSpot.
- Scroll down to Parameters.
Connections
- Click Allow.
- BigQuery
- The Supermetrics API
