!! Some HubSpot fields require "Content" scope permission which can be only granted by HubSpot Super Admin users. If you have any other user level in HubSpot, read this article first: I don't get any results for certain fields in my HubSpot query !!
- Go to https://datastudio.google.com/u/0/datasources/create?connectorId=AKfycbwd1l7EF-Gc6sSDy-UkusG2b3YFpNjChj--DVuBhLFmczfch45hUV-2f11kYLPK3Ujz
- Click the AUTHORIZE button to give permission to the connector to access your Data Studio account:
- A pop-up will ask you to log in with your Google account - select the same account you intent do use Data Studio with and then click Allowto accept the access request:
- Click the second AUTHORIZE button that appears to log into the data source itself:
- A pop-up may ask you to select a team, if you belong to multiple. Pick a team with your license to continue. If you do not belong to multiple teams, it will skip to the next step.
- Click "Start" on the new window that opens:
- Login with your HubSpot credentials:
- Choose which account you want to use:
- If you have sufficient permissions, click "Grant access":
- If you see this screen, ask your HubSpot subscription administrator to grant you higher permissions:
- After completing the authentication, you may still see buttons to authorize, in which case just refresh the page. Now you're ready to start building your dashboard.
Useful links:
Editing data source fields
How to create a time series chart
Can I Use Multiple Accounts in the Same Data Source?
Tips & Tricks
