This guide will walk you through how to authenticate or reauthenticate Newsletter2Go with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Newsletter2Go, you need a Newsletter2Go username and password, and an Auth-Key.
Find your Auth-Key
- Log in to Newsletter2Go.
- Click your account name in the top-right corner.
- Select Account.
- Click the API tab.
- Copy your Auth-key.
Supermetrics offers the Campaign Performance query type, which pulls data on the performance of email campaigns.
For Excel users
- Click Create query.
- Under Data source, select Newsletter2Go.
- Enter your credentials and click Log in.
- Click Allow.
- Under Select accounts, select the accounts.
- Navigate to Newsletter2Go and click Try.
- Click Authorize.
- If you’re authenticating the data source for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
- Select your accounts.
- Click Connecton the top right-hand side.
- Click the edit icon next to Newsletter2Go in the Data Studio sidebar.
- Scroll down to Parameters.
Before you can authenticate Newsletter2Go in Excel, you need to install the Supermetrics add-in.
- BigQuery
- Data warehouses and cloud storage (Amazon S, Google Cloud Storage, Snowflake, Azure Storage, or Azure Synapse)
- The Supermetrics API
Reauthenticate Newsletter2Go
