This guide will walk you through how to authenticate or reauthenticate Ad Data + Google Analytics in Data Studio. This is the only destination that supports this data source.
Before you can authenticate Ad Data + Google Analytics in Data Studio, you need to install the Supermetrics add-on.
To connect Supermetrics to Ad Data + Google Analytics, you need to meet the requirements set by each data source this connector uses. Follow the steps from the Before you begin sections in these guides:
- Navigate to Ad Data + Google Analytics and click Try.
- Click Authorize.
- Click Authorize.
- Under Select accounts/views, select your accounts/views.
When you're ready, learn how to create your first Supermetrics query with Ad Data + Google Analytics.
- Scroll down to Parameters.
