About Azure Storage prerequisites
Some requirements need to be met to start using Azure Storage as a Supermetrics destination. These prerequisites ensure that a working connection can be set up to successfully transfer data to your Azure Storage container.
About permissions
You may need specific permissions to verify these prerequisites are met. If you're unable to access some information, please get in touch with your Azure admin.
Prerequisites
Storage account with container support
Your destination should be an Azure Storage account that supports containers, such as BlobStorage, Storage, or StorageV2. See Azure documentation to learn more about storage accounts.
Roles and permissions
At the minimum, the role Reader & Data Access is required for sufficient permissions. The role should be applicable to the Azure Storage account in which your destination container is located. See Azure documentation for more information about storage roles.
Access key
The destination container needs to use an access key for authentication. See Azure documentation to learn more about access keys.
IP allowlisting
If your storage account only allows access from selected networks, IP allowlisting is needed. At the minimum, the role of the Storage Account Contributor is required to modify the firewall settings of a storage account. See Azure documentation for instructions on managing IP network rules
Grant access to these Supermetrics IP addresses. Don't forget to add your own IP address to avoid losing access to your storage account.
