How to manage your billing information and billing cycle
You can update your billing information on the Supermetrics Hub.
Important
Note that you need have the Owner, Admin, or Finance role in the team to update the billing information.
When making changes to billing information on the Hub, check from the top bar that you're in the right team. Switch teams, if necessary.
If you're unable to make the changes, please contact our support team.
If you're paying by credit card, follow these instructions to update your credit card details.
To change the company name and tax ID (VAT ID for EU customers), create a new billing entity with the new details, and change your old billing entity into the new one. See billing entity instructions below.
Change billing email address
  1. Go to the Billing page on the Hub.
  2. Update the necessary details.
You can add multiple billing email addresses to the Payer email list section. Alternatively, click Edit billing contacts in the billing entity details.
Change billing cycle
  1. Go to the Subscriptions page on the Hub.
  2. Select a subscription, and click Billing cycle at the bottom of the page.
  3. Change the billing cycle as required.
    • If you change to a longer billing cycle, the remaining prepaid balance will be applied as a discount directly to the total to pay now.
    • If you change to a shorter billing cycle, the remaining prepaid balance will be credited as a longer subscription period.
  4. Click Confirm.
Create a new billing entity
  2. Select a subscription, and click Billing entity at the bottom of the page.
  3. Click + Create new entity.
    Make sure to use unique names for your billing entities to avoid confusion.
  4. Fill in the details, and click Add.
Change billing entity
  3. Select a billing identity from the list, and click Confirm.
