How to fix data source permissions errors
This guide will walk you through how to fix permissions errors when you’re logging into a data source with Supermetrics:
  • It seems you tried to log in with a user that does not have (data source) enabled. Please try again with another user account.
  • Please login with a data source user that has access to at least one account.
  • We did not find any accounts with your login credentials. Please try again using a different login.
  • Invalid credentials/Invalid credentials provided.
  • User is not authorized to make this request.
  • This user does not have permission to read data.
  • User permission denied: user doesn’t have permissions for account.
Data source-specific errors:
  • Facebook Ads: Unsupported get request. Object with ID 'act_' does not exist.
  • Twitter Ads: This user does not have permission to read campaign data.
  • Twitter Ads : User is not authorized to make this request.
  • Twitter Public Data: Profile not found.
  • Instagram Insights failure: Fetching insights caused the following error: (#10) Application does not have permission for this action.
Permissions
Please check that your account’s user role level meets the data source’s access requirements. Refer to our authentication guides and follow the section Before you begin to learn more.
If you can’t change your access or permission level, contact your account administrator.
Further checks
Try these checks if the error persists after you've adjusted permissions.
Renew login
Renewing a login can help resolve permissions errors that persist.
Renew the authentication login (also known as a token) with the data source you’re encountering the error with.
If you encounter one of the errors above with Instagram or Facebook, reset the app permissions.
