This guide will walk you through how to authenticate or reauthenticate Moz with Supermetrics for Google Sheets and Data Studio.
Moz allows you to collect publicly available search engine data. To fetch more than 200 rows of data with it, you’ll need to use your own API credentials.
- URL metrics returns metrics for up to 50 URLs.
- Link metrics returns information about links between a target URL and other pages and domains.
- Under Data source, select Moz.
- Navigate to Report Configuration.
- Select the query type.
- Add URLs to the Type URL field. Separate multiple URLs with commas and no whitespace (,).
- Navigate to Moz and click Try.
- Click Authorize.
- Click Authorize.
- Select the query type and click Next.
- Scroll down to Parameters.
