Follow these steps to connect your Criteo data to Supermetrics.
To connect Supermetrics to Criteo, you need:
- An API user with a client ID and client secret
- Learn how to generate these in our Criteo permissions guide.
- An app with at least Read access for all elements of the Marketing API. To create these credentials, follow these instructions.
- If you're logged with an old Criteo app, you'll need to log out of Criteo and then log back again. To install a new app, follow these steps.
- Under Data source, select Criteo.
- Enter your Criteo client ID and client secret, and click Start.
- Navigate to Criteo and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Criteo requires authorization to connect to data").
