How to refresh your account data
If you’ve recently made changes to your Supermetrics queries for a particular data source — like adding new accounts, custom metrics, or new segments, for example — but they’re not showing in your reporting, you should refresh your account data.
  1. Go to the Subscriptions page on the Supermetrics Hub.
  2. Click on the subscription you'd like to look into.
  3. Scroll down to Data sources & accounts.
  4. On the right side, click Refresh account list.
    If you see a Manage button instead of Refresh account list, click Manage first and then Refresh from the view that opens.
  5. Finally, reauthenticate the data source to re-establish its connection to Supermetrics.
Refresh cache in Looker Studio
In Looker Studio, data might be loaded from the cache for better performance if you have many accounts.
Note that this depends on the data source behavior — not all data sources cache account data.
To refresh the cache:
  1. Click the Edit icon ( ) next to your data source (or click ResourceManage added data sources and click Edit there).
  2. Click Edit connection.
  3. Scroll down, and click the link following the "The account list was last fetched..." text. Note that this text shows only if the data source stores account data in the cache.
  4. Refresh the connector configuration page in Looker Studio.
