CJ Affiliate connection guide
This guide contains all permissions and requirements for connecting your CJ Affiliate data to Supermetrics.
To connect from Supermetrics to your CJ Affiliate account, you need a personal access token and your company ID (CID).
  • The personal access token is generated either by your admin or yourself at CJ Affiliate's developer portal.
  • You can see your company ID (CID) by clicking on your company name in the upper right corner on the CJ Affiliate platform. The CID number is shown under the CID column.
  • Commission detail report: The Commission Detail report is available to both advertisers and publishers to access nearly real-time commission data from their accounts.
When connecting to CJ Affiliate, you need to insert your CJ Affiliate credentials.
  1. Select the CJ Affiliate data source on the Supermetrics Hub or in the data destination.
  2. Insert the personal access token and your company ID (CID), and give a name for your login.
  4. Click Start.
  5. In your data destination, select the login you just named and, if prompted, select a query type.
You can also connect to CJ Affiliate from these destinations:
