This guide will walk you through how to authenticate or reauthenticate Pardot in Supermetrics for Google Sheets, Data Studio, and Excel.
To connect Supermetrics to Pardot, you need a user account in a Salesforce instance that's connected to Pardot, and a Pardot business unit ID.
- Log in to Salesforce.
- On the top right-hand side, click Setup.
- In the left-hand menu, navigate down to Platform Tools → Pardot → Pardot Account Setup.
- Copy the Business unit ID and Business unit name to your notepad. Keep them safe — you'll need them when you authenticate Pardot in Supermetrics for the first time.
If you can’t access the Pardot account's setup information, ask your Salesforce Administrator to provide you with the Pardot Business unit ID.
- Under Data source, select Pardot.
- Enter your Business unit ID and Business unit name and click Start.
When you're ready, learn how to create your first Supermetrics query with Pardot.
- Navigate to Pardot and click Try.
- Click Authorize.
- Click Authorize.
- Scroll down to Parameters.
Connections
- BigQuery
- The Supermetrics API
Reauthenticate
