This guide covers the basic functionality of the Supermetrics TikTok Ads connector, and gives examples of how to set up a query for Google Sheets, Data Studio, and Excel.
To connect Supermetrics to TikTok, you need:
- Ad account Analyst user role access. Learn how to manage permissions in TikTok Business Center.
Available fields
Main features
- Fetches all the main advertising metrics: impressions, clicks, CTR, cost, CPC, CPM, reach, conversions, conversion rates, CPA, and more.
- Splits the data by campaign, ad group, ad, or by time. It also supports hourly granularity.
- Inspects results by targeting demographics: location, language, age, gender, device, interest, and more.
- Fetches detailed conversion data for all the different in-app events or page events.
- Select Metrics.
- Under Options, you can add additional features to your query.
- Replace blank metric values with zeros.
- Combine new results with old.
- Format results for Data Studio (to import data from Google Sheets to Data Studio).
- No header row.
- Highlight values with colours (green, red, etc.).
- Advanced settings.
- Select Metrics.
Advanced options for Excel
- Set up BigQuery
- Set up the Supermetrics API
- We support only campaigns that use auction as buying type. Reservation ads are not supported at the moment.
