Once you’ve authenticated your connection to Shopify, you’re ready to create your first query.
This guide will walk you through Shopify query setup for Google Sheets, Looker Studio (formerly Data Studio), and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Shopify, you need:
- A Shopify store account with an Owner or Full Permissions user role level. Learn more about Shopify permissions.
Available fields
- Select Metrics.
- Under Options, you can add additional features to your query.
- Replace blank metric values with zeros.
- Combine new results with old.
- Format results for Looker Studio (to import data from Google Sheets to Looker Studio).
- No header row.
- Highlight values with colours (green, red, etc.).
- Advanced settings.
- Authenticate the data source in Looker Studio.
- Select the Date range from the auto or custom options. If you choose a custom date range, click the arrow on the top-right-hand side. Under a specific period, select a Start Date and End Date.
Advanced options for Looker Studio
- Select Metrics.
Advanced options for Excel
- Set up BigQuery
- Set up Supermetrics API
- If you encounter a 403 Forbidden error when authenticating to a Shopify Store or authentication failed error after reauthenticating Shopify, follow this guide.
