This guide will walk you through how to authenticate or reauthenticate Taboola with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and API.
To connect Supermetrics to Taboola, you need Account Manager user role access. Learn more about account permissions in Taboola's documentation.
- Under Data source, select Taboola.
- Enter your credentials and click Sign in.
- Select the profiles you'd like to use in your reporting.
When you're ready, learn how to create your first Supermetrics query with Taboola.
- Navigate to Taboola and click Try.
- Click Authorize.
- Click Authorize.
- Under Query type, select the query type.
- Scroll down to the bottom of the page.
- To create a report with our template, select Use report template for new reports. To create a blank report, deselect this option.
Connections
- BigQuery
- Data warehouse and cloud storage (Amazon S3, Google Cloud Storage, Snowflake, Azure Storage, or Azure Synapse)
- The Supermetrics API
