Supermetrics Support Forum
First Steps (Getting Supermetrics Into Your BigQuery Project)
This guide will walk you through how to enroll in the Supermetrics data source connectors for use in Google BigQuery to transfer data.
  1. Navigate to the Google Cloud Platform Marketplace and search for Supermetrics.
  2. Click on the data source you wish to use in BigQuery to transfer.
    Example BigQuery data source for Facebook Ads
  3. Click ENROLLĀ to add the connector to your project. Note that you must be a Project Admin to do this.
    Orange arrow points to blue "ENROLL" button to start the process to add the data source to your project
  4. You will be given the option to select a project you want to use the data source with. Select the one you wish and click Continue.
    Example page to select the BigQuery project you wish to use the data source in.
  5. It will return to the main description page of the data source. It will note the data source has been enrolled successfully.
    Example showing the data source was enrolled into the project (green check icon).
  6. Click CONFIGURE TRANSFER to start using the data source! For more instructions, see How to Configure a Data Transfer in BigQuery.
