This guide will walk you through how to log in to a data source using the Supermetrics sidebar in Google Sheets. In the video below, we use Facebook Ads as an example.
Make sure you’ve installed the Supermetrics add-on before you begin.
- Open a Google Sheets file.
- Click Extensions → Supermetrics → Launch to open the sidebar.
- Under Data source, select the data source you want to add.
- Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our connection guides for the details and permissions each data source requires.
