Once you’ve authenticated your connection to Salesforce, you’re ready to create your first query. This guide will walk you through Salesforce query setup for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Salesforce, you need:
- API access enabled for a user profile in Salesforce, with rights to the objects, fields, and data you want to fetch.
- As the platform's permissions are highly customizable and will vary from instance to instance, you should contact your Salesforce system administrator for help. See how to troubleshoot permissions issues with Salesforce.
Here’s an example of sufficient user permissions:
Available fields
- Select Metrics.
- Under Options, you can add additional features to your query.
- Opportunities dates based on closed or created date.
- Replace blank metric values with zeros.
- Combine new results with old.
- Format results for Data Studio (to import data from Google Sheets to Data Studio).
- No header row.
- Highlight values with colours (green, red, etc.).
- Advanced settings.
- Select Metrics.
Advanced options for Excel
- Set up the Supermetrics API
