This guide will walk you through how to authenticate or reauthenticate Pinterest Ads and Pinterest Organic with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Pinterest Organic, you need:
- A user logged in as the Owner account of the profile (access to an Ad account won't allow access to organic data of the profile).
- The profile queried must be a business profile.
Here’s an example of sufficient user permissions:
To connect Supermetrics to Pinterest Ads, you need:
- A Pinterest user account with at least Admin or Campaign access to an ad account. Read Pinterest’s documentation for instructions on how to grant access to Pinterest Ad account.
Available fields
Visit our documentation site for a full list of the metrics and dimensions Supermetrics can pull from the data source. You can find the full list of data sources on the left side of the page.
- Select Metrics.
- Under Options, you can add additional features to your query.
- Replace blank metric values with zeros.
- Combine new results with old.
- Format results for Data Studio (to import data from Google Sheets to Data Studio).
- Highlight values with colours (green, red, etc.).
- Advanced settings.
- Select Metrics.
Advanced options for Excel
- Set up BigQuery
- Set up Data Warehouse and Cloud Storage products (Amazon S3, Google Cloud Storage, Snowflake, Azure Storage, or Azure Synapse)
- Set up Supermetrics API
