How to create a BigQuery transfer
Start transferring data into your BigQuery project by creating a transfer.
Before creating a data transfer in BigQuery, make sure you have enrolled the data source. It’s best practice to create a dataset as a destination for your data before creating the transfer, although a new dataset can also be created in the data transfer configuration.
Creating datasets and transfers requires specific user permissions in BigQuery. The easiest option is using the role BigQuery Admin to grant the user permissions for both. Another option is using a custom role for the user creating transfers, and granting the permissions bigquery.transfer.get and bigquery.transfer.update to that user on the dataset level.
Supermetrics' data sources for BigQuery require your dataset to be located in one of the following Google Cloud Regions
  • us
  • europe
  • asia-northeast1
  • asia-southeast1
  • europe-west2
  • australia-southeast1
  3. Click + Create transfer.
  4. Select the Supermetrics data source you want to use as the source type.
  5. Fill in the name and schedule details for the transfer.
  6. Select the destination dataset from your existing datasets, or create a new destination dataset.
  7. Set the Refresh window —the number of days you want to include in each data transfer. The default value is 2 days.
  8. Click Connect source.
    • A popup will open asking you to enable a third party connection. Click Accept agreement to proceed.
    • Follow the steps in the Supermetrics login window to log in to the data source and define the transfer settings.
    • Click Submit. You will be notified of a successful connection to the data source.
  9. Click Save to store the transfer.
Once your transfer has been saved, you’ll be taken to the Run history of the newly created transfer where you can follow its status.
