How to add and remove data source accounts and data source connections in Excel
This guide will walk you through how to add and remove data source accounts and data source connections in Supermetrics for Excel.
Data source accounts Data source connections
Add data source accounts
  2. Select your data source from the Data source dropdown.
  3. Navigate to the Select accounts dropdown. Different data sources might name this dropdown differently — for example, if you're using Facebook Ads, you'll see Select ad accounts, and for Google Analytics, you'll see Select views.
  4. Click the field and select your accounts from the list, or start typing an account's name to filter for it.
Remove data source accounts
  2. Click any query on the sheet that uses the data source you want to remove accounts from.
  3. Click x to close the Query info popup.
  4. Navigate to the Select accounts dropdown. Different data sources might name this differently — for example, if you're using Facebook Ads, you'll see Select ad accounts, and for Google Analytics, you'll see Select views.
  5. Click x next to the account name to remove it.
