Once you’ve authenticated your connection to StackAdapt, you’re ready to create your first query. This guide will walk you through StackAdapt query setup for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to StackAdapt, you need:
- An API key. Only StackAdapt account managers can create these. Learn more in StackAdapt's documentation.
Available fields
- Select Metrics.
- Under Options, you can add additional features to your query.
- Replace blank metric values with zeros.
- Combine new results with old.
- Format results for Data Studio (to import data from Google Sheets to Data Studio).
- No header row.
- Highlight values with colours (green, red, etc.).
- Advanced settings.
- Select Metrics.
Advanced options for Excel
- Under Options, you can add additional features to your query. Learn more about Supermetrics advanced settings in Excel..
- Set up BigQuery
- Set up the Supermetrics API
