This guide will walk you through how to authenticate or reauthenticate Mailchimp with Google Sheets, Looker Studio (formerly Data Studio), and Microsoft Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Mailchimp, you need a:
- Mailchimp user account with an Owner or Admin user role level. See Mailchimp’s documentation for instructions on how to grant access for a user account.
Here’s an example of sufficient user permissions:
Available fields
Incompatible fields
You might encounter this error when pulling data from Mailchimp in Supermetrics with either Google Sheets or Looker Studio:
Incompatible fields: IllegalDimensionMetricCombinationException.
To fix this error, follow these steps.
- Select Metrics.
- Under Options, you can add additional features to your query.
- Replace blank metric values with zeros.
- Combine new results with old.
- Format results for Looker Studio (to import data from Google Sheets to Looker Studio).
- No header row.
- Highlight values with colours (green, red, etc.).
- Advanced settings.
- Authenticate the data source in Looker Studio.
Advanced options for Looker Studio
- Select Dates. Choose one date range (today, yesterday, last week, etc). To select a custom date, you can insert the date manually in the Start and End fields in the calendar bar.
- Select Metrics.
Advanced options for Excel
- Set up BigQuery
- Set up Data Warehouse and Cloud Storage products (Amazon S3, Google Cloud Storage, Snowflake, Azure Storage, or Azure Synapse)
- Set up the Supermetrics API
