How to Refresh Tokens - Login Management in Team Site
You can manage you and your teammate's various authentication tokens in the Team Management site, under the LOGINS section. From there, you will be able to renew tokens as well as log them out to remove unneeded access or to fix certain issues with tokens.
Login Management is currently supported for the following Supermetrics products:
  • Supermetrics for Data Studio
  • Supermetrics for Excel
  • Supermetrics for BigQuery
  • Supermetrics API
  • Supermetrics for Netvisor
Please note that this guide is not applicable to Supermetrics for Google Sheets.
To refresh your tokens with Google Sheets, please create a support ticket. However, before creating a ticket, as a first step, please re-authenticate the data source: How do I Re-Authenticate a Google Sheets Connector?
Quick links:
Renewing a Login
This process can be used to renew an expired, stale, or problematic user logins (aka authentication token) that are causing errors in one of the supported products.
  1. Log into https://team.supermetrics.com/token-managementwith your license account.
    • If given then option to select a specific team, you will need to select the one with the products/licenses you wish to renew the token for. You can always switch teams in the tool if you select the wrong one.
  2. Check the list or use the search function to find the "Data source" and "Login" account pair you wish to renew.
  3. Click on Renew in that row.
    Orange box highlights a specific row for the Facebook Ads data source, and an orange arrow points to the "Renew" link to start the renewal process
  4. You will be prompted to start the login process for the data source. It will tell you the current login being used - you MUST log in as the same account as before.
    Orange box highlights where the login account will be listed. You must log in as the same account
  5. Click Start and this should take you through the login process for the data source. Follow the prompts to log in, making sure you use the exact same user as before.
  6. Once the login process is complete, your login token should be renewed and any authentication or expired token errors in the product should be fixed.
    Note that the UI does not update automatically, so you may need to reload the page to see the new created date for the updated login.
Removing a Login (Log Out)
This process can be used to remove unnecessary accounts, as well as remove expired, stale, or problematic user logins (aka authentication tokens) that are causing errors in one of the supported products.
  1. Log into https://team.supermetrics.com/token-management with your license account.
  2. Check the list or use the search function to find the "Data source" and "Login" account pair you wish to remove.
  3. Click on Log out in that row.
    Orange box highlights the row for Google Ads, and an orange arrow points to "Log out" to start the removal process for this user
  4. You will get a pop-up asking you to confirm you wish to log that user out of Supermetrics. Click OK to proceed.
    Example log out confirmation page, with orange arrow pointing to red OK button to proceed to remove the account shown
  5. There will be a confirmation and the pop-up will close itself automatically.
  6. The account will no longer be in the list and any queries/products that were using that account will now ask the user to log in again.
    Note if you log the wrong account out accidentally, you can always follow the standard data source connection steps for the product to log the account back in.
Issues?
If you have problems with using this functionality, please submit a support request that includes what team you are logged in as, what data source/login combination you were trying to change, and include any errors or screenshots of the problem so that we can assist.
