Semrush Analytics: Query setup guide
Once you’ve authenticated your connection to Semrush Analytics, you’re ready to create your first query.
This guide will walk you through Semrush Analytics query setup for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Semrush Analytics, you need:
Here’s an example of sufficient user permissions:
Available fields
Visit our documentation site for a full list of the metrics and dimensions Supermetrics can pull from the data source
Special requirements for queries using the Domain query type
In Semrush, the "Domain Vs. Domain" query type requires that a specific formatting be used in the Domains. If this isn't use, queries won't return data.
Format your Domain queries like this, with each additional domain you want to compare separated by a | character:
<sign>|<type>|<domain>
You can use the these values for the <sign> parameter:
  • + : Returns every keyword that the entered domains are ranking for in Google's top 100.
  • -  : Returns keywords that are unique to the first domain listed. You can view the keywords that the first domain ranks for, but the second does not rank for
  • *  : Returns keywords that are unique to each domain, not shared by any of the other domains listed.
You can use these values for the <type> parameter:
  • or : For organic keywords
  • ad: For paid keywords
The <domain> parameter will be the base domain for the site you want to compare, like supermetrics.com or ebay.com.
Here's an example that compares ebay.com to imdb.com, looking for the organic keywords that are unique to each of the two domains listed:
*|or|ebay.com|*|or|imdb.com
Please note that you can only compare up to 5 domains at a time.
Google Sheets Data Studio Excel Data Integrations
  1. Authenticate the data source in Google Sheets.
  2. Select Metrics
  3. Select Split by Dimensions.
    You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  4. Click Get Data to Table to create your query and pull your data.
  2. Under Options, you can add additional features to your query.
  • Error API units balance is zero: this error means you've run out of API units for your Semrush account and won't be able to make more queries until you purchase more units. Please check the status of your API limit on the Semush API site. Note that there may be some delays if you recently purchased more units, so if you get this error but do have units, wait some time and try again.
  • Problems using the 'Display date' Field field - There are some specific conditions to use this setting correctly. See Using the 'Display Date' Option for Semrush Analytics for more information on the setting.
  • If you see an error about metrics and dimensions not fetching together, or fields being incompatible, follow these steps to fix the issue.
  • If you see errors relating to quotas, or “daily query quotas”, read this guide.
