About Supermetrics Hub
The Supermetrics Hub is a place where you can manage your data sources, accounts, data integrations, and more. You can connect to new data sources, start new trials, and manage your teams and license details.
In addition to connecting to data warehouse destinations, you can also create data blends and custom fields on the Hub and use them in your reporting.
Note
When you log in to the Supermetrics Hub for the first time, you need to register your account using this link.
Navigation on the Hub
In the left-side menu, you can access the following subpages:
From the top bar, you can access the following menus:
