Follow these steps to connect your Amazon Ads data to Supermetrics and use your data in Excel as well as any of our data warehouse destinations and the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Availability
Amazon Ads is available only in Excel and our data warehouse and API data destinations.
To connect to Amazon Ads, you need an Amazon user account that has access to an ad account.
- If using a manager account to access a linked ad account, the Amazon user account needs to be an Admin in the manager account, and the manager account needs at least Editor permissions to the linked ad account.
- If the Amazon user account has direct access to the ad account, the Amazon user account needs at least Editor permissions.
- If using granular permissions in either case, the user/manager account must have view permissions to both Advertising reports and Campaign manager options.
Note that Agency profiles are not supported. For Agency profiles, use the Amazon DSP data source connector instead.
- Sponsored Products: Get data for Sponsored Products type ads
- Sponsored Brands: Get data for Sponsored Brands type ads
- Sponsored Display: Get data for Sponsored Display type ads
- Under Data source, select Amazon Ads.
- Log in to Amazon Ads.
- Navigate to Report configuration and select a query type.
- Click + Create transfer.
- Select the Amazon Ads data source.
- Accept the agreement.
- Click Authorize with Amazon Ads.
- Select the accounts and query type you'd like to include in your reporting and define the transfer settings.
- Click Submit.
- Click Save.
- Select the Amazon Ads data source, and click OK.
- In the transfer setup view, select the accounts and query type you'd like to include in your reporting.
- Click Create transfer.
- In the sidebar, click API.
- Click Select a data source.
- Select the accounts and query type to use in your query.
- Hover over the Amazon Ads data source, and click Connect.
