How to connect data sources to Looker Studio (formerly Data Studio)
The first step in moving your data in Looker Studio (formerly Data Studio) with Supermetrics is to connect to our platform.
You can connect to data sources to Looker Studio in 3 different ways:
Our connection guides include the specific requirements for connecting to each data source.
The following video shows how to connect to one of our most popular data sources — Facebook Ads — from the Looker Studio data source gallery.
Connect from the Supermetrics Hub
Follow these instructions to connect to the data source on Supermetrics Hub and use your connection in Looker Studio.
  1. Go to the Data sources page on the Hub.
  2. Scroll down to the list of data sources you haven't connected to. You see this list below your existing connections, under the title Connect to new data source.
  3. Hover over the new data source, and click Connect.
  5. Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our connection guides for the details and permissions each data source requires.
  6. Next, log in to Looker Studio with the same credentials you use to log in to Supermetrics Hub.
  7. Go to the Looker Studio data source gallery.
  8. Select the Supermetrics data source you connected to on the Hub.
  9. Click Authorize. The connection you created on the Hub shows in the view that opens.
  10. Click Complete and continue.
  11. Click Close this window to return to Looker Studio.
  12. Select the data source parameters — such as accounts to use or a report type — you'd like to use in your reporting. Click Next, if prompted.
  13. If the data source has a report template available, scroll down to the bottom of the page and select Use report template for new reports. To create a blank report, deselect this option. Note that not all data sources have report templates.
  14. In the pane's top right, click Connect.
  15. Click Create report.
  16. Click Add to report or Create report.
See the below instructions to connect to data sources from the Looker Studio data source gallery or from data source gallery on the Supermetrics website.
Connect from Looker Studio data source gallery
Follow these instructions to connect to a Supermetrics data source from the Looker Studio data source gallery
  1. Log in to Looker Studio with the same credentials you use to log in to Supermetrics Hub.
  2. Go to the Looker Studio data source gallery.
  3. Select a Supermetrics data source.
  4. You'll see two buttons that read Authorize. If you're using Supermetrics for the first time in Looker Studio, click the left-hand one and log in with the Google Account you use with Supermetrics.
  5. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Data source requires authorization to connect to data").
  6. Select a team that has access to the account you want to connect.
  8. Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our connection guides for the details and permissions each data source requires.
  9. Once you return to our connection flow, click Complete and continue.
  10. Click Close this window to return to Looker Studio.
  11. Select the data source parameters — such as accounts to use or a report type — you'd like to use in your reporting. Click Next, if prompted.
  12. If the data source has a report template available, scroll down to the bottom of the page and select Use report template for new reports. To create a blank report, deselect this option. Note that not all data sources have report templates.
  13. In the pane's top right, click Connect.
  14. Click Create report.
  15. Click Add to report or Create report.
Connect from Supermetrics website data source gallery
Follow these instructions to connect to a data source from the Supermetrics website.
  2. Navigate to the data source and click Start free trial.
  3. You'll see two buttons that read Authorize. If you're using Supermetrics for the first time in Looker Studio, click the left-hand one and log in with the Google Account you use with Supermetrics.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Data source requires authorization to connect to data").
  7. Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our connection guides for the details and permissions each data source requires.
  8. Once you return to our connection flow, click Complete and continue.
  9. Click Close this window to return to Looker Studio.
  10. Select the data source parameters — such as accounts to use or a report type — you'd like to use in your reporting. Click Next, if prompted.
  11. If the data source has a report template available, scroll down to the bottom of the page and select Use report template for new reports. To create a blank report, deselect this option. Note that not all data sources have report templates.
  12. In the pane's top right, click Connect.
  13. Click Create report.
  14. Click Add to report or Create report.
Next steps
Create a report with Supermetrics in Looker Studio.
If you run into trouble logging in or authenticating, it could be due to one of these issues. If the error's coming from Looker Studio itself, Google's comprehensive troubleshooting tips could help.
Account issues
If you or your organization uses multiple accounts to access either Looker Studio or your data sources, cookies and permissions can cause issues when logging in.
If Looker Studio automatically logs you in with the wrong account, clear your cookies before connecting to Supermetrics. This should help ensure that you’re logged in with the right account.
Authentication
If you get stuck in a loop with failed authentication, follow these instructions to diagnose and solve the problem.
Multiple accounts or logins
If you encounter an error message telling you that This action is not supported when you are signed in to multiple accounts, follow these instructions to solve the issue.
