Follow these steps to connect your G2 Reviews data to Supermetrics and use your in-depth product review data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
You can query data from G2 Reviews without logging in to G2.
To pull data on a product or service on G2 Reviews, you'll need to copy the identifier from its G2 Reviews URL.
For example, if the G2 Reviews URL is g2.com/products/example/reviews, its company ID is example.
Query type
- Reviews: Fetch up to 1,000 of the latest public reviews for a product or service.
- Under Data source, select G2 Reviews.
- Navigate to Report configuration and enter the software or service name to use in your report.
- Navigate to G2 Reviews and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "G2 Reviews requires authorization to connect to data").
- Select a Supermetrics team and a query type.
- Click Next.
- Enter the software or service name to use in your report.
- Click + Create transfer.
- Select the G2 Reviews data source.
- Accept the agreement.
- Click Authorize with G2 Reviews.
- Select the software or service name you'd like to include in your reporting and define the transfer settings.
- Click Submit.
- Click Save.
- Select the G2 Reviews data source, and click OK.
- In the transfer setup view, select thesoftware or service name you'd like to include in your reporting.
- Click Create transfer.
Click Select a data source.
- Navigate to Report configuration and enter the software or service name.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the G2 Reviews data source, and click Connect.
