Follow these steps to connect your Ahrefs data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Ahrefs, you need:
- An Ahrefs paid plan subscription with the Enterprise plan. Learn more about all pricing plans in Ahrefs’ documentation.
- An Admin or Owner user role level. See Ahrefs' documentation about member roles and access levels and how to add a new user to your account.
Ahrefs and Ahrefs (legacy)
We introduced a new version of our Ahrefs data source connector in February 2024. Our old Ahrefs (legacy) connector worked with the Lite plan for Ahrefs. For the new Ahrefs connector, you need to upgrade your plan to Enterprise. The Ahrefs (legacy) connector is deprecated and stopped working on March 1, 2024.
Multiple user accounts
It's not possible to add multiple user accounts in the same login for Ahrefs. To log in with a different user account, you need to log out from all other Ahrefs accounts in Supermetrics.
Target URL
We support HTTP, HTTPS, and WWW for the Target URL field.
- Overview: Pull overview metrics from Backlink profile, Organic search and Paid search.
- Backlinks: Understand specific referring pages yielding high and/or low traffic and their overall domain rating
- Referring domains: Shows website domains for which target URL is referring
- Organic keywords: Shows the organic keywords for which the target URL ranks for
- Top pages: Shows which pages of the target URL get the most organic search traffic
- Paid pages: Shows which pages of the target URL get the most paid search traffic
- Keyword explorer: Overview: Get relevant keyword ideas with search volume, keyword difficulty, and other advanced metrics
- Under Data source, select Ahrefs.
- Enter your credentials and click Log in.
- Select a query type, and add the target URL.
- Navigate to Ahrefs and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Ahrefs requires authorization to connect to data").
- Click Done.
- Select a Supermetrics team and a query type.
- Click Next.
- Add the target URL and other options.
- Click Create report again.
- Click + Create transfer.
- Select the Ahrefs data source.
- Accept the agreement.
- Click Authorize with Ahrefs.
- Click Submit.
- Click Save.
- Select the Ahrefs data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Ahrefs data source, and click Connect.
