Follow these steps to connect your Branch data to Supermetrics and use your data in Google Sheets, Excel, data warehouses, Power BI, and the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Branch account, you'll need a Branch key and secret. Get the key and key secret from Branch Dashboard → Account Settings → Profile.
To access the Query API, you need to have both Aggregate Data and Export access. Learn more about the Query API in Branch help.
- Summary (total): Get the raw organic data for app analytics from the Branch summary dashboard.
- Summary (unique): Get the unique data for app analytics from the Branch summary dashboard.
Take a look at this article to learn more about the Branch dashboard and the relevant query types and filters to use with Supermetrics.
- Under Data source, select Branch
- Enter your Branch key and secret.
- Navigate to Report configuration, and select a query type.
- Under Data source, select Branch.
- Click + Create transfer.
- Select the Branch data source.
- Accept the agreement.
- Click Authorize with Branch.
- Click Submit.
- Click Save.
Click New transfer. If you haven't created any transfers yet, click Schedule first transfer.
- Select the Branch data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Branch data source, and click Connect.
