Follow these steps to connect your Matomo data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect your Matomo account to Supermetrics, you need your Matomo base URL and your authentication token.
These instructions apply to both Matomo cloud-based version and on-premise installation.
- Log in to Matomo and open your dashboard.
- Take a look at the URL in your address bar.
- The first part of the URL before index.php is your base URL to use for login. For example: https://yourcompany.matomo.cloud
- Log in to Matomo, and open your dashboard.
- On the upper right-hand side, click the cogwheel icon to get to the Administration page.
- On the left-hand side, under Personal, click Security.
- Scroll down to the Auth tokens section and click Create new token.
- Enter your password to continue.
- Enter a description for the token, for example, “Supermetrics”.
- Click Create token.
- Copy the token and store it in a secure place for later.
Set up your Matomo queries using any of the query types described below.
- Visitor overview: Engagement metrics for the whole website.
- Visitor devices: Engagement metrics by device type.
- Visitor locations: Engagement metrics by country.
- Visitor language: Engagement metrics by web browser language.
- Pages: Engagement metrics by specific website pages.
- Channels: Acquisition and engagement metrics by channel type.
- Referrers: Acquisition and engagement metrics by specific referrers.
- Campaigns: Acquisition and engagement metrics by campaigns.
- Campaign keywords: Acquisition and engagement metrics by keywords used in campaigns.
- Search engines: Acquisition and engagement metrics by search engine.
- Search keywords: Acquisition and engagement metrics by search keywords.
- Ecommerce overview: Overall ecommerce sales for the whole website.
- Ecommerce products: Ecommerce sales by specific products.
- Under Data source, select Matomo.
- Enter your base URL and auth token.
- Enter a name for your account for you to identify it later.
- Navigate to Matomo and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Matomo requires authorization to connect to data").
- Enter a name for the account for you to identify it later.
- Select the query type you want to fetch data for, and click Next.
- Click + Create transfer.
- Select the Matomo data source.
- Accept the agreement.
- Click Authorize with Matomo.
- Click Submit.
- Click Save.
- Select the Matomo data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Matomo data source, and click Connect.
