Follow these steps to connect your AppsFlyer data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to AppsFlyer, you need:
- Account admin access
- API token (V2.0)
- Log in to AppsFlyer.
- Click the email address in the top right corner to open the user menu drop-down.
- Click Security center.
- Under AppsFlyer API tokens, select Manage your AppsFlyer API tokens.
- Copy the V2.0 API token.
Learn more about retrieving and managing your tokens in AppsFlyer's documentation.
Supermetrics supports 2 report types to fetch performance data on how different marketing channels and user acquisition sources perform.
- Aggregated performance (Pull API) report: Get basic aggregated performance data for your mobile apps. This report is available for all AppsFlyer users.
- Aggregated performance (Master API) report: Fetch more granular data with less restrictive rate limits, including ad group, ad, and keyword splits. The Master API requires a separate subscription; please contact AppsFlyer to gain access. Learn more about the Master API in AppsFlyer's documentation.
- Event data export: Fetch raw event level data, each row is one event logged in AppsFlyer.
The raw data from the Event data export query type (any fields that begin with raw_data_) is only available in data warehouse destinations and the Supermetrics API. You also need an Enterprise AppsFlyer subscription with raw data API enabled.
- Under Data source, select AppsFlyer.
- Enter your API token.
- Navigate to AppsFlyer and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "AppsFlyer requires authorization to connect to data").
- Click + Create transfer.
- Select the AppsFlyer data source.
- Accept the agreement.
- Click Authorize with AppsFlyer.
- Click Submit.
- Click Save.
Click New transfer. If you haven't created any transfers yet, click Schedule first transfer.
- Select the AppsFlyer data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the AppsFlyer data source, and click Connect.
