Follow these steps to connect your LINE Ads data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the LINE Ads data source connector, API access must be enabled for the relevant Group on your LINE Ads account. Please contact your LINE account manager to enable this.
Once API access is enabled, you need a copy of the group ID, access key, and secret key of the group you want to connect to.
- Log in to the LINE Ad Manager.
- Navigate to the Groups page.
- The group ID is shown in the table next to the group name, in the format “G123456789”.
- Select the group you want to fetch data for.
- Click Menu in the top left corner.
- Under Settings, click Group settings.
- Copy the API access key and API secret key to a safe place. If you cannot see the secret key, click Regenerate your API secret key.
- Campaign performance: Get aggregated performance data on campaign, ad group and ad level.
- Under Data source, select LINE Ads.
- Enter your group ID, access key, and secret key.
- Navigate to LINE Ads and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "LINE Ads requires authorization to connect to data").
- Select a query type.
- Click Next.
- Click + Create transfer.
- Select the LINE Ads data source.
- Accept the agreement.
- Click Authorize with LINE Ads.
- Click Submit.
- Click Save.
- Select the LINE Ads data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the LINE Ads data source, and click Connect.
