Follow these steps to connect your AdRoll data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to AdRoll, you need Administrator or General User role access. Learn how to add or edit an AdRoll user in AdRoll's documentation.
- Under Data source, select AdRoll.
- Enter your email and password, and click Sign in.
- Click Authorize.
- Navigate to AdRoll and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "AdRoll requires authorization to connect to data").
- Click Authorize.
- Click Authorize.
- Click + Create transfer.
- Select the AdRoll data source.
- Accept the agreement.
- Click Authorize with AdRoll.
- Click Authorize.
- Click Submit.
- Click Save.
- Select the AdRoll data source, and click OK.
- Click Authorize.
- Click Create transfer.
- Click Select a data source.
- Click Authorize.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Click Authorize.
- Hover over the AdRoll data source, and click Connect.
- Click Authorize.
