Follow these steps to connect your Flashtalking data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Before using the Flashtalking data source connector, you need the following:
- A Flashtalking username and password. The username and password are the same as those you use to log in to the Flashtalking Hub Reports application.
- API access for your Flashtalking account, including access to the Campaign Manager API.
- Campaign: Measure paid media performance. Get data about clicks, cost, and interactions. Group the data by date, content, placement, advertiser, and so on.
- Under Data source, select Flashtalking.
- Enter your username and password.
- Navigate to Flashtalking and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Flashtalking requires authorization to connect to data").
- Select the accounts to use in your report and a query type.
- Click Next.
- Click + Create transfer.
- Select the Flashtalking data source.
- Accept the agreement.
- Click Authorize with Flashtalking.
- Click Submit.
- Click Save.
- Select the Flashtalking data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Flashtalking data source, and click Connect.
