How to connect to data sources from Supermetrics Hub
You can connect to all your data sources from the Supermetrics Hub. You can add new connections and share links with external stakeholders to connect to different data sources.
On the Data Sources page on the Hub, you can manage your active data connections to data sources and add new connections. At the top, you see a list of data sources you have already connected to. Below is a list of data sources that you can connect to.
Note
When you log in to the Supermetrics Hub for the first time, you need to register your account using this link.
Connect to new data source
  1. Go to the Data sources page on the Hub.
  2. Scroll down to the list of data sources you haven't connected to. You see this list below your existing connections, under the title Connect to new data source.
  3. Hover over the new data source, and click Connect.
  5. Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our connection guides for the details and permissions each data source requires.
Add new connection
  2. Go to the list of data sources you have connected to.
  3. Click the data source.
  4. Click Add new connection.
  6. Depending on the data source, enter your credentials and click Start, or click Start directly and then log in to the data source. See our connection guides for the details and permissions each data source requires.
If you need to connect to a data source that you don't have direct access to, you can share an authentication link with someone outside your organization. The person you share the link with must click the link and authenticate the connection to the data source as instructed in our connection guides.
  4. Click Share authentication link. You can now share the authentication link with the person who has the necessary credentials. The authentication link is valid for 12 hours.
