Adjust connection guide
This guide contains all permissions and requirements for connecting your Adjust data to Supermetrics.
To connect Supermetrics to Adjust, you'll need an API token to access your account, and an app token to identify the app that you want to fetch data from.
You'll need to connect each app to Supermetrics separately.
Get your API token
  1. Log in to Adjust and open your dashboard.
  2. Click the menu in the top left corner to open the sidebar.
  3. In the bottom left, click My profile.
  4. In the right sidebar, click API token.
  5. Copy the API token, and keep it secure.
Get your app token
  1. In the Adjust dashboard, open the app you want to connect to Supermetrics.
  2. Copy the URL from the address bar in your browser. The string after /default/ is your app token.
    For example, in a URL ending in /#statistics/overview/default/abcdefg, the app token would be abcdefg.
  3. Copy the token.
  • Datascape
When connecting to Adjust, you need to insert your API token and app key when prompted.
  1. Select the Adjust data source on the Supermetrics Hub or in the data destination.
  2. Enter your API token and app token.
  5. Click Start.
  6. In your data destination, select the query type to use, if prompted.
You can also connect to Adjust from these destinations:
