Follow these steps to connect your Adobe Analytics and Adobe Analytics 2.0 data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, and data warehouses. Adobe Analytics 2.0 is also available in Power BI and the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Adobe Analytics 2.0 is in Early Access, which means we're still fine-tuning all of its features. It's available to use for free until the full release. We'd love to hear your feedback.
There are two ways to authenticate Adobe Analytics and Adobe Analytics 2.0:
- Connect with OAuth Server-to-Server (recommended)
These authentication methods both work differently and have different advantages.
Authentication method | Details |
OAuth Server-to-Server |
OAuth |
To connect Supermetrics to Adobe Analytics or Adobe Analytics 2.0 with OAuth Server-to-Server you need:
- A System Administrator or Developer user role in your Adobe account organization.
- It also requires explicit access granted to see the report suites, reports, segments, and custom fields. Visit Adobe’s help center to learn how to change user roles.
When you're ready, follow our detailed guide to create the credentials and connect your Adobe Analytics account to Supermetrics.
To connect Supermetrics Adobe Analytics or Adobe Analytics 2.0 with OAuth, you need:
- An Adobe ID linked to Experience Cloud with Web Service Access enabled
- The linked ID needs access to the report suites, reports, segments, and custom fields you want to use in your reporting. Visit Adobe’s help center to learn about granting and changing account permissions.
- Under Data source, select Adobe Analytics or Adobe Analytics 2.0.
- Select an authentication method and enter your credentials. These depend on your authentication method — OAuth only needs an email and password, while OAuth Server-to-Server needs the client ID, client secret, and credential name.
- Navigate to Adobe Analytics and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Adobe Analytics requires authorization to connect to data").
- Select accounts and segments to use in your report.
- Click + Create transfer.
- Select the Adobe Analytics or Adobe Analytics 2.0 data source.
- Accept the agreement.
- Click Authorize with Adobe Analytics or Adobe Analytics 2.0.
- Click Submit.
- Click Save.
- Select the Adobe Analytics or Adobe Analytics 2.0 data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Select the Adobe Analytics 2.0 data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Adobe Analytics or Adobe Analytics 2.0 data source, and click Connect.
