This guide will walk you through how to authenticate or reauthenticate Optimizely with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Optimizely, you need Administrator or Pro user access to an ad account. See Optimizely’s documentation to learn how to grant access.
- Under Data source, select Optimizely.
- Enter your email address and password, and click Log in.
When you're ready, learn how to create your first Supermetrics query with Optimizely.
- Navigate to Optimizely and click Try.
- Click Authorize.
- Click Authorize.
- Enter your email address and password and click Log in.
- Scroll down to Parameters.
Connections
- Choose to make the connection shared or private.
- BigQuery
- The Supermetrics API
Reauthenticate
