You can download the newest version from www.supermetrics.com/download.
We have a button for migrating reports from the old version, but if you have built something very complex, it may not be imported correctly.
You can also use multiple Data Grabber files simultaneously, so you can keep the old file and use the new one just for those reports that need more rows.
