Twitter Premium connection guide
Follow these steps to connect your Twitter Premium data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Twitter Premium, you need:
  • A Twitter developer account
  • A valid subscription to Twitter's Enterprise API access (starting at 42,000 USD a month)
  • A live Twitter application (app) tied to your developer account, set up to work with Supermetrics
  • The API client ID and secret for that app so you can log in to Supermetrics
  • A Twitter Premium license for Supermetrics, with Historical Tweets report feature enabled
Contact our sales team to get started. We can help you with the setup process.
Note that Twitter Premium doesn't support multi-account logins or agency access. The API doesn't allow you to fetch data from multiple user accounts with one login — you'll need to add each user account separately.
  • Tweet engagement: Impression and engagement data for Tweets up to 90 days
  • Common account information: General information about the profile, such as description, location, and friend and follower count.
  • Tweet historical: Data for Tweets older than 90 days.
  3. Click Create new query.
  4. Under Data source, select Twitter Premium.
  5. Enter your Twitter app’s API key and API key secret.
  7. Click Start.
  8. Enter your credentials, and click Authorize app.
  9. Select the accounts you'd like to include in your reporting.
  10. Navigate to Report configuration and select a query type.
Contact us to get access to the Twitter Premium data source in Looker Studio.
  1. On Looker Studio, you'll see two buttons that read Authorize. If you're using Supermetrics for the first time, click the left-hand one and log in with the Google Account you use with Supermetrics.
  2. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Twitter Premium requires authorization to connect to data").
  3. Select a team that has access to the account you want to connect.
  5. Enter your Twitter app's API key and API key secret.
  6. Click Start.
  7. Enter your credentials, and click Authorize app.
  8. Select the accounts you'd like to include in your reporting.
  9. Select a query type, and click Next.
  10. In the pane's top right, click Connect.
  11. Click Create report.
  12. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Twitter Premium.
  4. Enter your Twitter app's API key and API key secret.
  6. Click Start.
Data warehouse
  3. Click + Create transfer.
  4. Select the Twitter Premium data source.
  7. Accept the agreement.
  8. Click Authorize with Twitter Premium.
  9. Enter your Twitter app's API key and API key secret.
  10. Click Start.
  11. Enter your credentials, and click Authorize app.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the Twitter Premium data source, and click OK.
  7. Enter your Twitter app's API key and API key secret.
  8. Click Start.
  9. Enter your credentials, and click Authorize app.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  6. Click Start.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Twitter Premium data source.
  6. Enter your Twitter app's API key and API key secret.
  7. Click Start.
Supermetrics Hub
  4. Hover over the Twitter Premium data source, and click Connect.
  6. Click Start.
