To connect your Rakuten Advertising data to Supermetrics, you first need to create a report in Rakuten Advertising itself that includes all the data you want to add to your reports. It'll give you the credentials you need to import that data with Supermetrics.
First, create a report in Rakuten Advertising that includes all of the data you want to fetch with Supermetrics.
You can also use an existing report — if you'd rather do this, you can skip these steps and follow the instructions to get your report key and API token.
Create a report
- Log in to Rakuten Advertising.
- Navigate to Reports, and click Reporting.
- Select an existing report, or build a new one. We recommend selecting every column you want to use in Supermetrics (but bear in mind that reports with more columns will load more slowly).
- Adjust your report's settings — you can make further changes in Supermetrics once it's connected, too.
- Click Save.
Get your report key and API token
- Open the report you want to use with Supermetrics.
- Open the dropdown next to "View report".
- Click Get API.
- You'll see your report's API URL. This contains your report key and API token.
- Copy the text between /reprots/ and /filters in the URL. This is your report key. Save it in a safe place.
- Copy the text after &token=. This is your API key. Store it securely.
Example report token and API key
ran-reporting.rakutenmarketing.com/en/reports/[report-key]/filters?date_range=this-month&include_summary=Y&tz=GMT&date_type=transaction&token=[APITOKEN]
- Click Create query.
- Under Data source, select Rakuten Advertising.
- Enter your report key and API token.
- Give this account a name — this can be anything that helps you distinguish this account from the others you use in Supermetrics.
- Navigate to Rakuten Advertising and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Rakuten Advertising requires authorization to connect to data").
