Outbrain Amplify upcoming changes to region codes - Oct. 4th, 2021
In order to provide more accurate and granular reporting information, Outbrain is changing their campaigns to use a new standard to determine geographical regions for targeting. This change will take place on October 4th.
This means that any queries for the Outbrain Amplify data source that use filters or otherwise rely on the current region settings may need to be updated before October 4th. Details related to the changes made by Outbrain can be found here.
What you need to do
If you don’t use geographic reports or breakdown by region, no action is required.
If you use filters or have any business logic that relies on the current values for geographies or regions, you may need to adjust them to work with the new region codes.
