This guide will walk you through how to authenticate or reauthenticate Facebook Political Ads in Supermetrics for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Facebook Political Ads, you need to:
- Confirm your identity on Facebook
- Register as a Facebook developer and create a Facebook developer application
For Excel users
Before you can authenticate Facebook Political Ads in Google Sheets, you need to install the Supermetrics add-on.
- Click Create query.
- Under Data source, select Facebook Political Ads.
- Enter your App ID and App Secret. Learn how to find these credentials in our permissions guide.
- Select your query type.
- Navigate to Facebook Political Ads and click Try.
- Click Authorize to authorize Supermetrics in Data Studio.
If you're authenticating the data source for the first time, log in with the Google account you use with Supermetrics. Click Allow. - Click Authorize to log in to Facebook Political Ads.
- Under Select accounts, select the accounts.
- Click Connect on the top right-hand side. This will open a full list of fields available in this connector. You can skip this list.
- Scroll down to Parameters.
- Make the connection private → unselect Share this connection with Team Supermetrics.
Make the connection shared → select Share this connection with Team Supermetrics. - Enter your App ID and App Secret. Learn how to find these credentials in our permissions guide.
- Under Query type, select the query type.
- BigQuery
- The Supermetrics API
