Tumblr Public Data: Authentication and reauthentication guide
This guide will walk you through how to authenticate or reauthenticate Tumblr Public Data with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and API.
Tumblr Public Data does not require any access requirements/permissions.
Data protection agreement
If you have any questions about how Supermetrics handles and secures your data, read our policy on data privacy and security.
  2. Click Add-ons → Supermetrics → Launch to open the sidebar.
  3. Under Data source, select the data source.
  4. Navigate to Report configuration.
    Under Query type, select the query type.
    Search posts by tags. To select multiple tags, please separate them with commas or new lines.
    Search blogs by usernames. To select multiple usernames, please separate them with commas or new lines.
  5. As additional filters, you can:
    Translate data into one specific language.
    Choose the number of rows per item.
Reauthenticate
Learn how to reauthenticate the data source with Supermetrics Google Sheets.
  • If you're missing an account from the drop-down list, follow these steps.
